Hello Guest it is November 13, 2026, 10:36:03 AM
Author Topic: Change direction of the work area  (Read 28892 times)
Offline AGOMA
  •  10 10
« on: August 16, 2016, 02:21:33 AM »
Hi. First post so please be gentle.  ;D
..and please excuse my bad english.
I can not find how to change direction of the work area?
When I run the machine to home pos, it goes to the lower right corner, which is correct.
But when I run a job I have to run to the upper left corner and put zero because the job would go toward + and not -.
Anybody know how to change this?
see attached image.
Many thanks
  •  9,377 9,377
Re: Change direction of the work area
« Reply #1 on: August 16, 2016, 02:55:53 AM »
I think you are going to get lots of differing views on this (perhaps controversial) topic.
Whilst the medium to upper range CAD/CAM software allows the home position (X0, Y0) to be in any corner (including centre) the basic CAD/CAM packages generally only allow the home position to be in the bottom left corner.
In my opinion, your machine should be set-up with X0, Y0 in the bottom left corner of the work-piece with +X moving the cutter to the right of the work and +Y moving the cutter to the rear of the work ( Axis direction can be changed by altering the Direction Active Low state in Config. / Ports & Pins / Motor Outputs ).
Offline AGOMA
  •  10 10
« Reply #2 on: August 16, 2016, 03:55:26 AM »
Thanx Tweakie for your answer.
humm,  controversial topic?? ???
Is it possible for you to suggest new topic so I can change, it is not meant to offend anyone. this is because my bad English.  :'(
I bought a broken multicam machine that I built for MACH 3.
This has its homing in the lower right corner.
I have been using Sketchup with sketchucam.
When I export gcode after moving the zero point to the other side of the job, it becomes empty in gcode. but I can try to move the home position to the lower left corner, so maybe it will be better.
but if I change the Direction Active Low state in the Config. / Ports & Pins / Motor Outputs. it will be mirrored then?
Many thanks for the reply
  •  9,377 9,377
« Reply #3 on: August 16, 2016, 04:41:26 AM »
Absolutely nothing wrong with your English sir - it is just my opinion that the topic is controversial only because many people will have different views regarding the origin and home positions.
If +X moves the cutter to the right of the workpiece and +Y moves the cutter to the rear of the workpiece then it will not be mirrored.
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: August 16, 2016, 09:44:35 AM »
On your sketches, both appear wrong to  me - the Y is wrong in the first and the X is wrong in the second - this is of course assuming that machine home would be front-left corner.
The corner it moves to when doing a home does not really matter as it can be set to home on the right but in reality it will place the real home/zero position to the left - read up on home switch offsets ;)
Likewise the home position chosen in CAM does not matter - what DOES matter is that you set the same home point on the material as was chosen in CAM or odd things can happen.
« Reply #5 on: August 16, 2016, 01:18:53 PM »
As Dave says, you must use a standard right hand coordinate system, which neither of the ones you show are.
Offline AGOMA
  •  10 10
« Reply #6 on: August 16, 2016, 03:26:57 PM »
Hi. Now I got it to work. I and as you say. I was wrong about the coordinates.
Now I home at the front right corner and x+ takes me to the far right and y+ to the left  8)
But I can't get the homing with my slave axis to work.  ???
My slave A axis stops when the X is home. So if The x i not straight I won't compensate for this..
I tried to change to refcombination(9) but not.
Are they any script the home them separately?
Starts at the same time and stops at the sensor?
Thanx  ::)
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: August 16, 2016, 03:33:12 PM »
do you have two home switches on the slaved axis - you need one at each side
Offline AGOMA
  •  10 10
« Reply #8 on: August 16, 2016, 03:57:05 PM »
Yes I have one for a and one for x.
They are tested and dedicated in ports and pins.
« Reply #9 on: August 16, 2016, 08:41:59 PM »
In General Config, make sure that Home Slave with Master is NOT checked.
