Hello Guest it is November 24, 2026, 03:12:00 PM
Author Topic: Serial Plugin Questions  (Read 7545 times)
« on: August 11, 2016, 08:43:25 AM »
I was delighted to see the new serial plugin.
However i cannot find any docs or examples on its use.
i found this update description on the PDMX website
        - - - Build 4.2.0.2914 - 02 March 2016 - - -
7) Added plugin to allow send and receive from RS-232 serial port.
8) Convert LUA environment to use dynamic runtime to support loadable
   LUA modules. LUA RS232, LFS file system, LUA Sockets with TCP modules  now provided.
Where could i find Docs and more importantly , some examples of its use
any info greatly appreciated.
Re: Serial Plugin Questions
« Reply #1 on: August 11, 2016, 04:33:49 PM »
FWIW - There is a sample program here, which shows how to use some of the functions:
         C:\Mach4Hobby\Modules\luars232-Example.lua
If you so a web search for "luar232" there are other examples of usage, but an actual API document wasn't obvious.
Bob
« Reply #2 on: August 11, 2016, 06:30:40 PM »
Thank You !
