Hello Guest it is October 25, 2026, 05:31:52 AM
Author Topic: Invert the Axis enagle for the Motor driver of the Pokey 57cnc breakout board  (Read 34281 times)
The stepper motor driver board (gShield by Syntetos) I am using with the Pokey 57cnc breakout board wants a low (gnd) 'axis enable' and the breakout board is giving me a high (+5v) 'axis enable'. Is there a way to invert this 'axis enable' in the plugin setup or do I need to try a hardware fix? Thanks Attley
With Mach4 invert Enable is the first box in pulse engine tab in the plugin.
