Hello
Guest
it is
November 13, 2026, 06:39:27 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Z plunging deeper after each retraction. Not mechanical
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Z plunging deeper after each retraction. Not mechanical (Read 19156 times)
garyhlucas
660
Re: Z plunging deeper after each retraction. Not mechanical
Reply #10 on:
July 23, 2016, 04:32:14 PM »
If that is being measured without the load of a tool and cutting forces then I think you are done, it isn't likely to get any better.
CDA001
22
Reply #11 on:
July 23, 2016, 06:49:03 PM »
Gary,
You are probably right. I may not mess with the 1.8Kw - overkill and probably won't make a difference. It is just odd that a C2 accuracy screw is not running in the tolerance it should.
Thank you again my friend.
Gio
Print
Pages:
1
2
Go Up
« previous
next »
