Hello Guest it is November 13, 2026, 06:39:32 AM
Author Topic: Z plunging deeper after each retraction. Not mechanical  (Read 19158 times)
Re: Z plunging deeper after each retraction. Not mechanical
« Reply #10 on: July 23, 2016, 04:32:14 PM »
If that is being measured without the load of a tool and cutting forces then I think you are done, it isn't likely to get any better.
« Reply #11 on: July 23, 2016, 06:49:03 PM »
Gary,
You are probably right. I may not mess with the 1.8Kw - overkill and probably won't make a difference. It is just odd that a C2 accuracy screw is not running in the tolerance it should.
Thank you again my friend.
Gio
