Hello
Guest
it is
October 31, 2026, 09:50:54 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
General CNC Chat
Building or Buying a Wood routing table.. Beginnners guide..
trying to figure out steps per mm
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: trying to figure out steps per mm (Read 47318 times)
wes709
37
on:
July 19, 2016, 02:39:46 PM »
Trying to figure out my steps per mm Using the Rep Rap Calculator
Here is the link to the NEMA 23 Steppers that i bought as a kit with the cnc controller.
http://www.ebay.ca/itm/3-Axis-3A-Stepper-Controller-Cnc-Kit-Nema23-24V-Psu-For-Milling-Machine-/401075212293?hash=item5d61f21005:g:Hq0AAOSwzJ5XZ8Oz
Here is the link to the leadscrew i have selected
http://www.banggood.com/T8-800mm-Stainless-Steel-Lead-Screw-Set-with-Shaft-coupling-and-Mounting-Support-p-1062920.html
From the above sites i was able to determine my:
Motor Step Angle 1.8
Leadscrew Pitch 2mm
I have the dip switches on my cnc board set to be at 1/8 micro step.
The part that i think im messing up is the pitch preset where i am only guessing that is m8 1.25 mm per rotation.
With the above information i get 800 steps per mm which seems absurd
PLEASE SOMEONE HELP ME if i roatate the rod 1 full revolution it travels 8.1mm
Am i just messing up the calculation???
ger21
6,295
Re: trying to figure out steps per mm
Reply #1 on:
July 19, 2016, 02:49:34 PM »
Looks like the screw is labeled vaguely, and the lead is actually 8mm.
So with 1600 steps per rev, divided by 8, you should have 200 steps/mm.
wes709
37
Reply #2 on:
July 19, 2016, 02:53:56 PM »
Where did you get the 1600 im curious
wes709
37
Reply #3 on:
July 19, 2016, 03:06:49 PM »
I have entered the setting at 200steps per mm , if i get my calipers and move the z axis down 10 mm on mach3 display should that be 10mm of travel on the leadscrew ?
ger21
6,295
Reply #4 on:
July 19, 2016, 03:46:19 PM »
If the display (DRO) shows 10mm, then the Z axis should move 10mm.
wes709
37
Reply #5 on:
July 19, 2016, 04:12:00 PM »
Thanks for your quick replies i think im on to something . I have a video here to show you what i actually get when i move the z axis down 10 mm on the DRO
https://www.youtube.com/watch?v=r5UPgpz9q7o
Thanks again for your help it looks though as if im only seeing close to 5 mm when i move it 10 on DRO any ideas?
ger21
6,295
Reply #6 on:
July 19, 2016, 04:20:02 PM »
Then change it to 100 steps/mm
wes709
37
Reply #7 on:
July 19, 2016, 04:49:08 PM »
it was actually the other way . it was 400 steps per mm. Thanks so much for your help!
ger21
6,295
Reply #8 on:
July 19, 2016, 06:56:31 PM »
Quote from: wes709 on July 19, 2016, 02:53:56 PM
Steppers are 200 steps/rev.
With 1/8 microstepping, it's 8x 200.
wes709
37
Reply #9 on:
April 15, 2017, 07:52:32 PM »
Im Back !!! i am trying to add a rotary axis,,, i cannot get the axis to move as the A , only the X and is there some sort of settings to change this to be a rotary axis in mach 3? here is a video to help explain.
https://www.youtube.com/watch?v=o54M_phYJpY
Thanks!
Print
Pages:
1
2
Go Up
« previous
next »
