Hello Guest it is October 22, 2026, 10:32:02 PM
Author Topic: Motors are not operating correctly  (Read 33978 times)
  •  9,374 9,374
Re: Motors are not operating correctly
« Reply #20 on: August 04, 2016, 11:14:23 AM »
Also, what is the likelihood that a power supply issue would be the cause of the direction problems that I outlined in prior posts?
I would say it is almost certain that the bad power supply is the cause of the direction problems  ;)
Offline Davek0974
  •  2,606 2,606
« Reply #21 on: August 04, 2016, 12:50:11 PM »
That sounds expensive for a psu ??
What size - voltage and current is it meant to be ?
« Reply #22 on: August 04, 2016, 01:26:37 PM »
The psu came installed in a prewired control box.  I priced the individual components that were recommended on various forums, and it was roughly the same to wire myself in-comparison to a prewired control box.  Also, I lack the electronic expertise to tackle such a project.  The following link outlines the components in my setup.   http://www.automationtechnologiesinc.com/products-page/g0704-kit/3-axis-cnc-stepper-control-box  I am questioning the overall quality of the psu, since it has lasted only two years with minimal usage.
« Last Edit: August 04, 2016, 01:35:08 PM by JD2016 »
Offline Davek0974
  •  2,606 2,606
« Reply #23 on: August 04, 2016, 01:45:57 PM »
So its just the 5v psu thats failed?
I should think just about any 5v switch-mode psu would work, the BOB only draws minimal current and a 2A unit here in the UK would be about £10
I have not checked all the details of your unit though so please take my advice carefully ;)
