Hello Guest it is October 26, 2026, 05:46:50 PM
Author Topic: need help! Newbie's problems  (Read 26828 times)
Re: need help! Newbie's problems
« Reply #10 on: May 23, 2007, 03:29:58 PM »
What is the steps per on the X axis?
« Reply #11 on: May 23, 2007, 03:34:03 PM »
20000
« Reply #12 on: May 23, 2007, 03:39:05 PM »
Try it at 22727 and see what happens.
« Reply #13 on: May 23, 2007, 03:50:03 PM »
What is the mystic number?
200 steps X 10 micSteps = 0.1 Inch Then
1 Inch = 20000, it's wrong?
Thank you.
« Reply #14 on: May 23, 2007, 03:54:51 PM »
you have 20,000 and it moves 22mm when you command it to move 25 so I just wondered what it would move if you put 22727.
« Reply #15 on: May 24, 2007, 06:10:30 AM »
Hood,thank you very much.You guide me to the
right direction.
I caught out that my screw drive have 5/8" diameter,
then it's TPI = 11, and pitch is 2.308 mm.
I did the changes in Step per and now all works
properly!
Thanks!Best regards.
                               efimius.
« Reply #16 on: May 24, 2007, 12:01:25 PM »
Glad you are sorted.
