Hello Guest it is October 24, 2026, 04:32:17 PM
Author Topic: User macros that produce problems...  (Read 14728 times)
« on: May 23, 2007, 06:54:22 AM »
I have a program that produces G code from drawings ("Promotion Nest").
The programs sets at the begining of the program M28 and at the end M29.
So, i created two new macros (in the macros folder) M28 and M29.M1S .
M28 contains only that: ActivateSignal(output1)
and M29 contains: DeActivateSignal(output1)
Now when i open a file (any file), the toolpath screen does not show the drawing, and sometimes if i try to move by right clicking, goes back to the first screen.
If i delete these two files, the screen shows the drawings as well.
Do you have any idea of what is going on?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: User macros that produce problems...
« Reply #1 on: May 23, 2007, 11:48:05 AM »
Are your macros in the profile you are using?
or you can try this.
in your macro type :-
If not IsLoading() then
  activatesignal(output1)
end if
Graham.
« Last Edit: May 24, 2007, 11:48:29 AM by Graham Waterworth »
« Reply #2 on: May 24, 2007, 12:27:56 AM »
Yes the macros are in the profile that i'm using.
Graham, the first line produces compilation error:
If not Isloading() Then
Endif
Why is that?
  •  2,785 2,785
« Reply #3 on: May 24, 2007, 01:33:53 AM »
OK, try it this way
If IsLoading() then
else
end if
Graham.
« Last Edit: May 24, 2007, 11:48:17 AM by Graham Waterworth »
« Reply #4 on: May 24, 2007, 02:12:58 AM »
Graham, still has compilation error.
Why is it so difficult for the program to do it?
Its a simple code.
  •  2,785 2,785
« Reply #5 on: May 24, 2007, 11:52:21 AM »
They work here, here are the 2 macros :-
Try them and let me know.
Graham.
« Reply #6 on: May 26, 2007, 03:27:46 AM »
Braham, thanks!
Its fine!
