Hello Guest it is November 12, 2026, 09:27:39 PM
Author Topic: Rapid Speed Screenset  (Read 10602 times)
« on: July 14, 2016, 05:17:33 AM »
We have a new screenset with Mach3 and now the SHIFT key on the keyboard is not allowing rapid speeds. If I press SHIFT and arrow the machine doesn't move at all, and when only arrow key, the machine moves at slow speed...
Anyone knows what that could be?
CD
  •  9,377 9,377
Re: Rapid Speed Screenset
« Reply #1 on: July 14, 2016, 06:37:54 AM »
It may depend on your new screenset but…
Pressing the TAB key brings up the MPG window the Slow Jog Rate determines the Arrow key % jog rate and this is then overridden to 100% jog rate by the Shift + Arrow keys. If your screenset does not work this way then check out the screenset for the problem.
« Last Edit: July 14, 2016, 06:39:38 AM by Tweakie.CNC »
« Reply #2 on: July 14, 2016, 06:51:39 AM »
Ok - this is a whole new screenset, only 1 page (not even tab window)...
I understand the Slow Jog Rate, that is actually build into main screen. I can set it at any % and that works, but I don't know how to ensure SHIFT works with screenset. Do I need a certain button to enable SHIFT function on the main screen set? Or is there a hidden setting somewhere?
CD
« Reply #3 on: July 16, 2016, 12:55:25 PM »
Load a standard screenset and see if it works, if it does then it must be something in your screenset so if you attach it and the associated bitmaps (if any) I will take a look.
« Reply #4 on: July 19, 2016, 03:34:27 AM »
Hi Guys, just an update!
I finally have it working. It seems like you have to tell the screenset to work in Continuous mode and then it will stay like that. I added buttons and played around until I got it working, and I'm sure that because I don't have buttons to change the Continuous mode that I can remove buttons again after I have it working.
This is what I did: I added 2 buttons on the screen: Toggle Jog Mode and Set Jog Mode Continuous, then added a LED - Continuous Jog Mode. When I start Mach3 the CONT JOG LED was off. Then I pressed the Toggle Jog Mode until Continuous LED came on, and then press Set Jog Mode Continuous. After that it seemed to work. I closed Mach3 and when I started it again the Continuous LED was already ON and everything works!
Hope this might help somebody! :)
CD
