Hello Guest it is October 20, 2026, 02:52:25 PM
Author Topic: Y axis movement opposite.  (Read 18744 times)
Offline Davek0974
  •  2,606 2,606
Re: Y axis movement opposite.
« Reply #10 on: July 16, 2016, 02:31:17 AM »
Yes,
if you think about it, the movement result is identical - the TOOL moves to the same position on the bed mill and the gantry mill, it's our brain that messes things up - with both mills at X0 & Y0, an instruction to go Y100 will send the bed mill table towards you and the gantry will move away from you but both tools will be at Y100
The only way i find to use both machines is to always look at the tool and think where i want it to go, ignore the bed or gantry as one will go the opposite way ;)
