Hello Guest it is November 23, 2026, 01:04:04 PM
Author Topic: MACH3 for Plasma Machine  (Read 8549 times)
« on: July 09, 2016, 04:17:51 PM »
HOw do I get a Mach 3 program for plasma cutting only tilldirt@itstriangle.com
( Posted by Vernella June 24, 2016 )
Which Mach 3 program do I buy that will run my plasma cutter tilldirt@itstriangle.com
( Posted by Vernella June 28, 2016 )
Hi My plasma quit moving and I am trying to buy a new program to fix this tilldirt@itstriangle..com
( Posted by Vernella July 03, 2016 )
This the third time I have ask does standard Mach 3 run a plasma cutting table I have not been able to
find the answer Dick tillldirt@itstriangle.com
( Posted by Vernella July 09, 2016 )
( This topic created for Vernella by RICH )
Re: MACH3 for Plasma Machine
« Reply #1 on: July 09, 2016, 04:22:36 PM »
(Reply by Hood - July 09, 2016, 12:40:16 PM)
Mach3 is one programme and it comes standard with Lathe, Mill, Plasma options, you can also make it run many other types of machines such as coil winders, pipe benders, metal folders etc etc etc.
Whether it will work with your plasma will depend on how your original control worked, for example did it use the parallel port or did it have a dedicated card in the pc.
« Last Edit: July 09, 2016, 04:25:33 PM by RICH »
« Reply #2 on: July 09, 2016, 04:44:13 PM »
Vernella,
Suggest you post some information about your Plasma Machine if you want more specific information on using Mach as the controller
for it. Also the software, if any you are using, to generate code.
