Hello Guest it is November 13, 2026, 10:16:24 PM
Author Topic: 57CNCdb25 Fast_USB Driver Not installing for Mach4  (Read 17152 times)
« on: June 30, 2016, 12:47:26 PM »
I have a Pokeys 57CNCdb25 connected (USB) to Win10 laptop with mach4 running.
I'm trying to set up the Pokeys without a (G540) drive controller connected.
I Installed required files into plugin folder per instructions.
Mach4 crashes when saving configuration, and when restarting Mach4, configuration dialog exists, but not fully configurable.
Bulk interface appears in device manager with missing drivers noted when plugged into USB.
Fast_USB Driver/folders do not exist anywhere in the system.
Can Fast_USB Driver install without a drive controller connected?
What am I missing?
Offline NeoTO
  •  504 504
    • PoLabs
Re: 57CNCdb25 Fast_USB Driver Not installing for Mach4
« Reply #1 on: June 30, 2016, 10:00:13 PM »
Install PoKeys configuration software first and update the firmware. The software also comes with a USB driver.
https://www.poscope.com/index.php?route=product/product/download&download_id=122&product_id=87
« Reply #2 on: June 30, 2016, 11:03:39 PM »
NeoTO,
that installed the driver, no more Mach4 crashes.
I was unable to find reference to that setup file on  the PoKeys website...
Thanks again,
Roger
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: July 01, 2016, 11:55:42 PM »
Hi, Roger
We will work on making it more clear - it is a standard PoKeys setup package named PoKeys v4.2.1, PoBlocks, Mach3 plugin (18.6.2016).exe
« Reply #4 on: July 02, 2016, 02:11:49 AM »
Good.
Adding a Mach4 version of that in the Mach4 section would work for me...
Roger
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #5 on: July 08, 2016, 01:09:53 AM »
We updated the PoKeys57CNC and PoKeys57CNCdb25 devices homepage to include links to related content.
See here: https://www.poscope.com/PoKeys57CNCdb25 and https://www.poscope.com/PoKeys57CNC
« Reply #6 on: July 08, 2016, 09:50:46 AM »
Nicely Done!
Roger
