Hello
Guest
it is
October 25, 2026, 07:03:10 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Help Again
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Help Again (Read 8815 times)
Kevindh
8
Help Again
on:
June 30, 2016, 07:05:24 AM »
I am a newbie and have my 3040 machine all set up now. I have loaded the Gcode and I have the piece of wood on the bed. I have moved the cutter to the corner and I have then clicked each XYZ to 0 . When I click the start cycle it goes back to oo on the bed. How do I save the home to my work piece and not the bed.
Im running mach3
Much appreciated
Kev
Logged
Davek0974
2,606
Re: Help Again
Reply #1 on:
June 30, 2016, 09:49:32 AM »
Thats usually a setting the software that generated the g-code, on mine it is anyways
Logged
joeaverage
7,663
Re: Help Again
Reply #2 on:
July 02, 2016, 05:26:54 AM »
when you zero XYZ does the current work offset reflect that? Can be seen on the 'offsets page'. Should
see also which workoffset is active, most commonly G54.
You may need to include a G54 command at the beginning of your part code.
Logged
Print
Pages:
1
Go Up
« previous
next »
