Hello Guest it is November 24, 2026, 03:12:06 PM
Author Topic: Save Profile  (Read 8140 times)
Offline Stuart
  •  311 311
Save Profile
« on: June 24, 2016, 09:13:19 AM »
Sorry for a dumb question but how do I save the configuration when I have it set up
In Mach3 I store the xml file off the pc , what do I need to save in Mach4
Stuart
Re: Save Profile
« Reply #1 on: June 24, 2016, 10:06:40 AM »
There is a function in Mach4 to capture all the configuration information into a
single file. It can be found at:
HELP > Support > Package Current Profile
This will produce a file with the current profile name and an extension of m4prof.
You will be offerd a choice of where to save this file. It is actually a zip file and if
you change the extension you can open it in a zip viewer to see what is in it
if you desire.
To restore it on a new system, first install Mach4, then use the Mach4Loader
to import the profile using the button at the bottom right of the loader window.
Steve Stallings
PMDX
Steve Stallings
www.PMDX.com
Offline Stuart
  •  311 311
Re: Save Profile
« Reply #2 on: June 24, 2016, 10:43:16 AM »
Thank you Steve for your prompt answer
Now I can get a BU of it done
Stuart
