Hello Guest it is November 03, 2026, 09:14:27 PM
Author Topic: Reading Inputs  (Read 26201 times)
Tom Byrd
Reading Inputs
« on: March 14, 2006, 10:43:00 AM »
There seems to be a little snaffoo with reading inputs.  My home inputs work fine for all six axis I'm using, but this code hangs:
     Code "g91g00 z-.52"
     SystemWaitFor(18)
     Code "g04 p2."
     Code "g91g00 z.5"
signal 18 is for Input 1 which shows on the screen just fine, but when I try to trigger something by it, it does nothing.  I've tried  reversing the "Active Low" check with no difference in results.  Maybe this isn't functional yet? Let me know, and I can work around it.
#2
I'm homing only X,Y,B,C.  The X and Y automatically ZERO, while the B and C don't, in fact won't.  When I try to change the DRO for the B and C, it reverts back to the previous numbers when I ENTER.  The only way I can get those two axis to cooperate is to exit the program then restart.  At this point it will allow me to change the #'s to ZERO.  Any Ideas?
     T. Byrd
