Hello Guest it is October 14, 2026, 05:33:30 AM
Author Topic: Adding New Home Switch  (Read 8517 times)
Offline kolias
  •  1,165 1,165
« on: June 19, 2016, 10:08:58 AM »
I would like to add a Home switch to my A axis and the easiest way to do it is to wire in series the X Home switch which is already wired to Pin 12 with the new A Home switch. Is there a problem with this setup or it has to be a separate wiring ?
Nicolas
Re: Adding New Home Switch
« Reply #1 on: June 21, 2016, 12:02:13 PM »
that will work just fine as long as both switches are normally closed type of switches.  When either switch is triggered both X and A will light up but it doesnt matter as they will never home at the same time.  I put many switches in series like that.  You could effectively put them all on the same pin if you had to.
Offline kolias
  •  1,165 1,165
« Reply #2 on: June 21, 2016, 02:09:13 PM »
All my switches are NC type. Thanks fixittt for your time
Nicolas
