Hello Guest it is October 24, 2026, 06:47:31 PM
Author Topic: GUI crash on Mach Config window  (Read 6958 times)
« on: June 19, 2016, 02:24:28 AM »
Hello guys,
did anyone experienced GUI crash when you have Mach Configuration window opened? All I need to do is to open Mach config screen, select Homing tab or Imput signals tab and click on backround (of example toolpath screen) and the GUI will crash with APPHANGB1 crash (MACH4GUI.EXE).  I have found it because I use touchscreen and sometimes I ,,misclick,,. I tried it on my home PC with mouse and its doing the same thing. Can you try it pls? Thanks.
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: GUI crash on Mach Config window
« Reply #1 on: June 19, 2016, 03:08:06 AM »
This is a focus issue between 2 windows, a quick but dirty way to sort this is to load your task manager and stop "mach configuration" NOT the core, this will destroy the configuration window and give focus back to the gui.
DazTheGas
