Hello Guest it is October 24, 2026, 12:00:13 PM
Author Topic: step rate on maxnc ol  (Read 11690 times)
mmihld
« on: May 22, 2007, 11:33:34 PM »
I finally got the mach3 running.  thanks for the advise.  it now seems to drive the motors, however, the step rate is too fast.  i did a search on this forum for this problem and i think in need a xlm file for the maxnc 10 ol.   i have searched for this, but cant find it!  anyone have the xlm file for the maxnc 10 ol??
Re: step rate on maxnc ol
« Reply #1 on: May 23, 2007, 05:17:16 PM »
I don't have the xml file for the maxnc ol. I have a maxnc cl2. Try setting the steps to 4000. This worked for my mill. If you hit the tab key you can also set your jog speed.
Jeff
« Reply #2 on: May 27, 2007, 12:36:14 PM »
Please change your Motor tuning settings under Config / motor tuning
Brian
www.newfangledsolutions.com
www.machsupport.com
mmihld
« Reply #3 on: May 27, 2007, 12:58:15 PM »
what should the settings be?
« Reply #4 on: May 27, 2007, 01:04:58 PM »
Set them to what you feel looks good :)
It is not the same for all machines :(
www.machsupport.com
