Hello Guest it is October 22, 2026, 09:58:06 PM
Author Topic: Problem with Spindle Speed Control  (Read 7239 times)
« on: June 13, 2016, 05:47:36 AM »
Hello,
I use Mach3Turn for Lathe with control about 2 printerports. In the diagnosticsmode i can see the indexsignal working, but in the manual or automatic mode the spindlespeed display shows allways zero. I have test this with a low and a high spindlespeed.
Have someone a idea what i made wrong?
Many thanks for your answer
Hans
Offline rcaffin
  •  1,073 1,073
Re: Problem with Spindle Speed Control
« Reply #1 on: June 22, 2016, 12:00:55 AM »
Check pin assignments. You probably have the index signal wrongly assigned. It should work.
Roger
