Hello Guest it is November 13, 2026, 08:41:57 PM
Author Topic: Pokeys 57E mapping to Mach3 PWM  (Read 11187 times)
« on: June 11, 2016, 01:13:30 PM »
How do I send the PWM signal from Mach3 to Pokeys 57E?  I can scale one of the 57E PWM outputs to 10V easily enough, but I can't figure out how to get the Mach speed signal into the 57E.
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys 57E mapping to Mach3 PWM
« Reply #1 on: June 18, 2016, 02:28:55 PM »
It should be really simple - open the PoKeys plugin configuration, switch to PWM tab in the settings, enter the PWM period in microseconds, then select what you want to do with each PWM channel. Simplest is to use the 'Map to DRO in %', which will use the selected DRO's value (multiplied with the optional multiplier setting) as the channels duty cycle.
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
