Hello Guest it is September 05, 2026, 09:25:05 PM
Author Topic: Mill Dual Z axis?  (Read 14774 times)
Offline Davek0974
  •  2,606 2,606
Mill Dual Z axis?
« on: May 31, 2016, 09:33:47 AM »
I'm in the process of converting my Bridgeport to CNC, servo's, CSMIO etc.
If I had a motor on the knee-lift screw as well could it be tied into the Z axis DRO in Mach3 as well as the normal Z axis ??
Only one would be moving at a time.
Just a thought.
Re: Mill Dual Z axis?
« Reply #1 on: June 01, 2016, 02:20:09 AM »
Don't think you would get away with that, could cause all sorts of issues.
Might be better setting as an A, B or C axis and using it solely for tool length offsets.
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: June 01, 2016, 02:33:03 AM »
Good point, just a thought.
Probably just fit a normal power-lift to it.
« Reply #3 on: June 01, 2016, 03:16:19 AM »
Power lift is good, the Beaver NC5 I have has it as standard and it saves the old arms :)
Only advantage having a servo would be it would be automatic.
If there was a tool changer then servo would be the way I go but as it doesn't then probably not worth the expense.
Regarding the power lift, a lot of people have just made up an end to fit in a cordless drill and use that, a  friend has done it and he says it works great, here is his mill.
http://www.machsupport.com/forum/index.php/topic,29886.0.html
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: June 01, 2016, 03:23:42 AM »
Thanks Hood, that Avon looks to have a bigger set of balls than the Bridgeport ;)
Nice enclosure too.
I have a feeling that there is a gap about as big as the Cheddar Gorge between my current experience level and that of just being able to close the door and press cycle start ;)
I want a little better than the drill lift idea, I have a geared motor that will do the job, its a bit big but it's free, VFD drive too :)
« Reply #5 on: June 01, 2016, 03:56:48 AM »
Yes, the Avon is about the same size as the Beaver NC5 I have and he did make a great job of the enclosure.
If you have all the stuff there then yes a drill doesn't make much sense, a geared motor is the way to go :)
(No subject)
« Reply #6 on: June 01, 2016, 08:13:25 AM »
Reflecting off the OP, would it be possibule to write G00 script which would use the knee as rapid Z and the quill as "feed" Z ?
Guess you would have to invert the -+ movement in the script depending on "which Z" is moving. But in the end, the tip of the tool will always be correct with the DRO.
Hummm ???
~ What was once an Opinion, became a Fact, to be later proven Wrong ~
  •  9,368 9,368
« Reply #7 on: June 01, 2016, 09:50:56 AM »
Hummm ???
Not sure if that could be made to work but it is certainly a very interesting idea.
« Reply #8 on: June 01, 2016, 11:22:04 AM »
The main issue would be the CSMIO/IP-A is closed loop and updates the DROs in Mach from encoder position.
 If wanting to update the Z Dro from both knee and quill you would have to feed both motors encoders to the same encoder inputs.
 I think that would cause a lot of issues with the IP-A and it would forever throwing  PID errors.
