Hello Guest it is November 22, 2026, 07:18:53 AM
Author Topic: Why does my router "Clonk"?  (Read 22599 times)
« on: May 31, 2016, 02:35:34 AM »
I have finally managed to complete the new control system, (Mach 3 driving steppers through a UC300 motion controller) for my 1325 Chinese router and am generally delighted with the results. Everything runs much smoother and more accurately but................. I am plagued by occasional "clonking" from mainly the Z axis. I can only assume this is the drive losing or gaining steps and sounds the same as when the system is first turned on and power is applied to the drivers. It doesn't seem happen during program execution but very often does during initial homing or manually positioning for the start of job. Anyone any ideas where I should be looking first? Many thanks in advance. Bob.
Offline Davek0974
  •  2,606 2,606
Re: Why does my router "Clonk"?
« Reply #1 on: May 31, 2016, 03:35:56 AM »
Any chance of a video - it could be backlash, a loose coupling, belt jumping teeth, drive issue :)
« Reply #2 on: May 31, 2016, 04:05:00 AM »
Unfortunately there is nothing to see, I've checked the mechanical linkage, belt tension etc and all is well there, it does sound like an electrical issue as it's exactly as when the drive is first powered on.
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: May 31, 2016, 04:15:55 AM »
Mine all clonk when powered-up, its the stepper motors stepping into a known position.
If its doing this same thing at other times it sounds like the drive is disabling/enabling or a power fault - check the lights (if any) on the drive when it does it.
« Reply #4 on: May 31, 2016, 06:11:43 AM »
Ok, I think I'll start by replacing the "Z" axis drive and see how it goes, maybe a faulty drive?
Offline Davek0974
  •  2,606 2,606
« Reply #5 on: May 31, 2016, 06:39:56 AM »
Could be, could be just loose wire etc
« Reply #6 on: June 23, 2016, 09:54:31 AM »
OK just to bring this back to the top, I've changed the Z motor and the driver and all is still the same  :'(
Also checked the wiring and am sure all is good. Any further ideas where to look?
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: June 23, 2016, 10:29:08 AM »
any chance of sticking a video clip up on youtube??
« Reply #8 on: June 23, 2016, 11:44:53 AM »
I'll give it a go but there really isn't much to see. Hopefully the sound if I can capture it will help. It's peculiar in that it only seems to do it when the axis is moving slowly, if I run it at rapid speed it appears to be OK.
Is it possible it could be something to do with the step per rev setting (currently 1600) resonating with something mechanically?
Offline Davek0974
  •  2,606 2,606
« Reply #9 on: June 23, 2016, 12:24:16 PM »
I doubt it, steps per is relative only to distance travelled and the drive system mechanically.
So, travelling slowly it clonks, how slowly?
No clonks at rapid speeds or fast moves?
