Hello Guest it is November 13, 2026, 10:02:14 AM
Author Topic: OEM button can't work in M99999 program  (Read 6666 times)
« on: May 29, 2016, 10:01:32 AM »
Hi everyone,
i designated number1037 to an oem button, vb script has a simple program to toggle its LED to turn ON and Off.
If it is allocated in macropump program, i press this button on the screen, a simple program (a testing IF cause) in macropump program has response and also, the screen LED toggles.
However, when i put this testing IF cause inside the M9999 program. Actually, this a subroutine program calleư by a toolchanger program M6start. When i entered M6T1 in the MDI entrance, toolchanging operations proceed until to this testing IF cause. Actually, i made a looping on this IF cause, it seems that it still can detect the state of this 1037 button. But, on the screen, i am no longer able to toggle this button, nor the LED changes the state. The program cannot link with it..
It seems that i designed this button can only work on macropump program but not in toolchanging program....Are there any solutions or did i mess up something?
Thanks in advance.
