Hello Guest it is October 24, 2026, 05:52:47 PM
Author Topic: M Codes in MDI  (Read 10174 times)
M Codes in MDI
« on: May 27, 2016, 04:29:25 PM »
I'm trying to test some M codes in MDI without much luck.  M codes that trigger outputs seem to work fine, but anything to create motion does not work.  See code below.  I tried all of the code execute functions with no luck.  The function is running because last error is updating correctly, just not getting an movement.  If I hit run in the editor, it runs fine.  If I step through the code it runs fine.  It does not work by typing M101 in MDI or by calling M101 in a Gcode file.  The file name is m101.mcs.  What could be wrong to make it run fine in the editor and fail in MDI and gcode?
Code: [Select]
function m101()
    -- GoTo Safe Z
    inst = mc.mcGetInstance()
    mc.mcCntlSetLastError(inst, 'Move to SafeZ')
    local SafeZ = scr.GetProperty('droSafeZ', 'Value')
    local CodeLine1 = 'G00 Z' .. SafeZ
    mc.mcCntlGcodeExecute(inst, CodeLine1)
    --mc.mcCntlMdiExecute(inst, CodeLine1)
    --mc.mcCntlGcodeExecuteWait(inst, CodeLine1)
end
 m101()
end
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: M Codes in MDI
« Reply #1 on: May 27, 2016, 04:47:01 PM »
Just tried using the sim and worked fine using had to add a number as I dont have the dro, try putting a messagebox below it to see what is getting passed to the gcode
Code: [Select]
function m101()
    -- GoTo Safe Z
    local SafeZ = 5 --scr.GetProperty('droSafeZ', 'Value')
end
 m101()
end
DazTheGas
Re: M Codes in MDI
« Reply #2 on: May 27, 2016, 06:13:54 PM »
Interesting....
If I remove this...
    local EndZ = scr.GetProperty('droEndZ', 'Value')
    local CodeLine1 = 'G00 Z' .. EndZ
and just do this...
    local CodeLine1 = 'G00 Z0.5'
It works. Yet when I look at what's getting passed to mc.mcCntlGcodeExecute, it is the same.  CodeLine1 is the same in both cases.
« Last Edit: May 27, 2016, 06:19:28 PM by rrc1962 »
Re: M Codes in MDI
« Reply #3 on: May 27, 2016, 08:49:06 PM »
Evidently you can't use a screen element in a M code...
This works...
    val = '0.50000'
    gCode1 = 'G00 Z' .. val
    mc.mcCntlGcodeExecute(inst, gCode1)
This does not...
    val = scr.GetProperty('droTest1', 'Value')
Re: M Codes in MDI
« Reply #4 on: May 27, 2016, 09:01:09 PM »
Screen elements must not be visible to a normally running M code.  The following code works....
    val = mc.mcProfileGetString(inst,'PersistentDROs', 'droTest1', '1')
Offline smurph
  •  1,575 1,575
Re: M Codes in MDI
« Reply #5 on: May 27, 2016, 10:01:43 PM »
Correct.  There is a LUA instance in the screen and a separate instance for the M code macros.  The only thing available to both is the mc.* API.  scr.* is only available in the screen scripts.
