Hello Guest it is November 22, 2026, 06:27:06 AM
Author Topic: Spindle Feedback Ratio  (Read 9283 times)
« on: May 20, 2016, 02:04:37 AM »
Hello Guys
I have Mach4 - latest version - going through an Ethernet Smooth Stepper with their latest plug in, driving my spindle through a PWM signal.
The motor behaves wonderfully and seems to be very accurate to the commanded speed.
I have an index input signal from a slotted optical switch which I also believe works well.
My trouble is wildly varying spindle speed read out on my screen. When I look at the machine diagnostics page I see the Spindle Feedback Ratio changing constantly - it is set to 1 in the config settings and I just want it to stay at 1.
Is there any way it can be locked at 1?
Steve
Re: Spindle Feedback Ratio
« Reply #1 on: May 20, 2016, 07:47:00 AM »
Yup....... that will be updated soon but you can edit your screens PLC script now to fix it if you want to.
Code: [Select]
--Change this ***********************
--  Set Feedback Ratio DRO
--local spindlerpm = scr.GetProperty('droSpindleRPM', 'Value');
--local truerpm = scr.GetProperty('droTrueRPM', 'Value');
--local feedbackratio = (truerpm / spindlerpm);
--scr.SetProperty('droFeedbackRatio', 'Value', tostring(feedbackratio));
--To this ********************************
local range, rc = mc.mcSpindleGetCurrentRange(inst)
local fbratio, rc = mc.mcSpindleGetFeedbackRatio(inst, range)
scr.SetProperty('droFeedbackRatio', 'Value', tostring(fbratio))
« Reply #2 on: May 20, 2016, 08:59:07 AM »
Thanks Mate :)
« Reply #3 on: May 20, 2016, 10:48:25 AM »
No problem, hope it gets you sorted.
