Hello Guest it is September 26, 2026, 03:03:10 AM
Author Topic: Mach4 Quicky #3 Using wxTimer  (Read 21313 times)
Offline DazTheGas
  •  778 778
  • DazTheGas
« on: May 19, 2016, 04:24:50 PM »
Ever needed a timer in mach4 that wasnt in a loop like a = a +1 etc then try wxTimer
https://youtu.be/nkCx2xdoPEw
The Code
Code: [Select]
TimerPanel = wx.wxPanel (wx.NULL, wx.wxID_ANY, wx.wxDefaultPosition, wx.wxDefaultSize )
timer = wx.wxTimer(TimerPanel)
TimerPanel:Connect(wx.wxEVT_TIMER,
    function (event)
    -- Whatever code or function you need here
timer:Stop()
end)
timer:Start(10000)
DazTheGas
Offline dah79
  •  35 35
Re: Mach4 Quicky #3 Using wxTimer
« Reply #1 on: May 19, 2016, 09:19:53 PM »
Thanks Daz for the great explanation and video!
« Reply #2 on: May 21, 2016, 04:05:13 PM »
That is a good one Daz! Very useful. Thanks!  :)
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #3 on: May 26, 2016, 03:35:32 AM »
There seems to be a bug somewhere, not sure where? as you can see from the video I dont get an error when running. but an error does exist if I run in script debug mode?
If you do get an error then change the first line to TimerPanel = wx.wxPanel (wx.NULL, wx.wxID_ANY, wx.wxDefaultPosition, wx.wxSize( 500,300 )) - Thanks Brett for the fix.
DazTheGas
