Hello Guest it is November 13, 2026, 12:15:21 PM
Author Topic: Wrong Coordinate Numbers  (Read 7811 times)
« on: May 19, 2016, 04:24:51 AM »
I have a CNC 3080 and using Mach3. Everything appears to be working fine, but the x and y coordinates are displaying incorrectly. I can move the y axis the entire length of the bed and the coordinate will increase or decrease (depending on the direction) a max of 1.2000.  ??? I have played with the steps with no luck. Is there a way to adjust the coordinate numbers to a different value?
Brandon
  •  9,377 9,377
Re: Wrong Coordinate Numbers
« Reply #1 on: May 19, 2016, 04:55:42 AM »
On the Mach3 Settings page you will find the Axis Calibration utility which will enable you to set your Steps per Unit. Just follow the on-screen instructions.
Also check that you have Mach3 set-up for the units you intend to use (Metric or Imperial).
