Hello Guest it is November 13, 2026, 07:19:31 PM
Author Topic: converting a chinese 6040  (Read 17962 times)
« on: May 17, 2016, 02:05:45 PM »
slowly busy converting my chinese 6040 to pokeys.
received my stepper drivers today and build a quick mock-up on a piece of MDF, running each stepper at 2.5A, so each has their own fan.
The machine already sounds better, so far very happy with this  ;D
Two things I have noticed though, I now and again get a "buzz" from the motors when not moving. not always, if it buzzes and I tap the jog key, it stops.
Also, when I click "Go to Zero", they stop at X0.0031 Y0.0031 for example. Not always though, sometimes a different number, does not go to exactly 0.0000 ? Anyone else seen this ?
Anyway, so far very happy .. and also very quick shipping from the guys at Polabs, both orders pretty much arrived the next day almost !! Happy chappy !
Offline NeoTO
  •  504 504
    • PoLabs
Re: converting a chinese 6040
« Reply #1 on: May 17, 2016, 02:31:49 PM »
Regarding the inaccurate 'home' position - what are you steps per unit settings? These may result in partial step that can not be executed by the device.
« Reply #2 on: May 17, 2016, 02:37:17 PM »
steps per unit is 320. 1/8 with 1605 ballscrew, 5mm pitch, so if my calculations are correct, 1600 / 5 is 320 steps per mm ?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: May 17, 2016, 02:49:11 PM »
Then,  X0.0031 Y0.0031 is one step in X and Y. This may be due to a rounding error in Mach3.
« Reply #4 on: May 17, 2016, 03:16:27 PM »
yes, might be. doesn't always happen, sometimes it goes to 0.0000 and other times not. can you only use mach3 with pokeys or are there other software too that will work ?
« Reply #5 on: May 18, 2016, 04:19:05 AM »
I have just checked with a demo version of mach4 and it doesn't seem to happen then, so looks like only in mach3. I was wondering if the kernel speed inside mach3 has any affect on pokeys or doesn't it matter ?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #6 on: May 18, 2016, 10:20:58 AM »
The kernel speed setting of Mach3 does not affect the PoKeys device operation.
