Hello Guest it is October 24, 2026, 06:47:34 PM
Author Topic: Mach4 Axis Calibration...  (Read 15549 times)
« on: May 13, 2016, 02:37:06 AM »
I saw some discussion about Mach4 not having the same calibration wizard to calibrate your axis steps that Mach3 has. Those discussions are a year old now, did that ever get implemented into Mach4?
Offline royce
  •  40 40
Re: Mach4 Axis Calibration...
« Reply #1 on: May 13, 2016, 06:13:01 AM »
No, and from what I heard it won't be. Its more or so a mechanical equation with no calibrating needed, ez pz leon squeezy. Daz did put up a video on youtube of configuring motors in Mach4 .
Bridgeport Series 1 Rigid Ram Retrofitted w/PMDX126 BOB, PMDX107, Hitachi WJ200 VFD,ESS, Leadshine DM2282 Drivers running Mach4 comfortably.
« Reply #2 on: May 13, 2016, 08:52:04 AM »
Thanks Royce, a search in Youtube did not seem to return a Mach4 calibration video, do you happen to have a link to it? I found a link in a thread but it was broken.
Offline royce
  •  40 40
« Reply #3 on: May 13, 2016, 08:57:03 AM »
Here you go. https://youtu.be/HIE0k6mu2yc?t=9m45s He is using ESS but the axis setup configuration is modified in Mach 4, not the plugin.
« Reply #4 on: May 13, 2016, 09:14:35 AM »
In case people want other helpful videos, a reminder that this link is the one referenced in the "Mach4 Videos" sub-section of this forum under the title "ESS and Mach4 Setup" here:
https://www.machsupport.com/forum/index.php/topic,29878.0.html
« Reply #5 on: August 24, 2017, 06:49:58 PM »
Did you get an update on the missing calibration issue?  Everything is old that I can find.
Offline Mauri
  •  328 328
« Reply #6 on: August 24, 2017, 10:48:29 PM »
There is a Wizard in Mach4 "StepPerUnitCalculatorBasic".
Mauri
Offline gorf23
  •  190 190
« Reply #7 on: August 30, 2017, 08:34:29 AM »
  CountsPerUnit, rc = mc.mcProfileGetDouble(inst,"Motor0", "CountsPerUnit", 2000.0)
this works for changing the CountsPerUnit but if you only want to read the CountsPerUnit to a variable
how would that be done?
Thanks gary
Offline Mauri
  •  328 328
« Reply #8 on: September 06, 2017, 09:10:03 PM »
gorf23,
This is my version of Ball Screw Calibration for Mach4.
Mauri.
Offline gorf23
  •  190 190
« Reply #9 on: September 08, 2017, 04:57:05 PM »
that looks good thanks
Do you have the code to write and read from and to the proper position of the ini file?
Thanks gary
