Hello Guest it is November 22, 2026, 07:10:56 AM
Author Topic: figure port address with windows 10  (Read 8396 times)
« on: May 09, 2016, 06:41:21 PM »
I have windows 10 and using a network cable to connect with.  How do I figure out port address.  Thanks Lenny
Re: figure port address with windows 10
« Reply #1 on: May 09, 2016, 07:53:45 PM »
Port address for what?
You say you're using a nic, you wouldn't need a port address.
« Reply #2 on: May 11, 2016, 01:08:09 PM »
Are you using a Ethernet smooth stepper?
The software plug in will use the standard LTP 378 port address.
You have to setup your network adapter and firewall to allow the mach3 plug in to use the network adapter
