Hello Guest it is November 25, 2026, 04:17:11 PM
Author Topic: Mach 4 Device Error  (Read 8116 times)
Mach 4 Device Error
« on: May 08, 2016, 03:00:21 PM »
In the beginning process of setting up my CNC Router, am running Mach 4, using a PMDX 424 Smart BOB, and using Vcarve Pro,  When running simple short jobs I have no problems, everything works great but when I run a longer job the Mach 4 runs about 90% and then stops, I get the following message error on the  History window : PMDX-SmartBOB-USB DEVICE ERROR: SYSTEM ERROR (18) packet timeout,  communications lost.
When this happens I loose all controls of the CNC machine I can not jog and of the access I have to turn close Mach4 and reboot the program,   am using a laptop with windows 10 and Norton 360 running in the background.  The laptop is a Dell and it only has 2.00 GB of RAM.
Any suggestions?
Re: Mach 4 Device Error
« Reply #1 on: May 08, 2016, 10:28:37 PM »
See the original thread on the PMDX support forums:
http://www.pmdx.com/PMDX-Forums/index.php?topic=268.0
Bob
