Hello
Guest
it is
November 13, 2026, 09:42:30 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Haas VF1 Conversion
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: Haas VF1 Conversion (Read 59715 times)
Mike VT
55
Re: Haas VF1 Conversion
Reply #40 on:
August 19, 2016, 09:45:09 PM »
Oh, be sure to crank up the speed. File is running at 10 inches per minute. Try it at much higher speeds to see the issue, although, I have seen it at even this low speed.
Logged
Carnoustie, Scotland
Reply #41 on:
August 20, 2016, 02:41:08 AM »
Ah I think the issue in the Arcs may be a Mach problem.
Yes I know 1 sec is slow but it is what it is with Mach I am afraid hence why I use a pot and even that is delayed but you get used to it.
Hopefully Mach4 will prove good enough to start using shortly, it will depend on the progress they make with the plugin of course.
Logged
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
