Hello Guest it is October 24, 2026, 10:49:37 AM
Author Topic: Life span of Mach3 maintenance/updates ?  (Read 8775 times)
« on: May 02, 2016, 10:45:17 AM »
Soon enough ill be buying Mach.
For the last couple weeks ive been playing with Mach3 while waiting for a little 6040 gantry router to be delivered. Delivery should be this week, if so, hopefully by the weekend everything will be working and then soon after that a full Mach license.
So the thought of how long will Mach3 be "supported" has come to mind.
_
~ What was once an Opinion, became a Fact, to be later proven Wrong ~
Re: Life span of Mach3 maintenance/updates ?
« Reply #1 on: May 02, 2016, 10:53:30 AM »
How do you define support?
It hasn't been updated in several years, and won't be updated again.
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: May 02, 2016, 11:20:33 AM »
But, as things go these days, with Mach3 you have such a massive user-base, the support is probably endless :)
Updates are not an issue - pick a flavour that works and stick with it - works for me anyway.
I was looking at LinuxCNC but already had a Mach3 working setup on one machine so went with the same again.
(No subject)
« Reply #3 on: May 02, 2016, 01:11:05 PM »
Sorry, support was the wrong word.
Updates and bug fixs. Thanks for the direct responce, ger21.
Looked at LinuxCNC a few years ago when i was day dreaming about machines, i run linux (ubuntu) on a headless server at home for close to ten years (think ver 10 was last update) and there desktop along with played around with different linux "flavors" so i have alittle exposore to linux. Mach seams (through reading) more stable and user base supported. Will give LinunxCNC a shot, but as it looks now, Mach will be my choice.
