Hello Guest it is November 07, 2026, 02:22:24 AM
Author Topic: Laser M10P1  (Read 80413 times)
  •  9,375 9,375
Re: Laser M10P1
« Reply #10 on: June 14, 2016, 09:48:17 AM »
Hi Bernd,
You are making progress.  ;)
Set PWM Base Frequency to 100 (spindle setup)
Set Output #1 to Active Low (output signals)
Set Clockwise (M3) to Output #1 (spindle setup)
You need to add spindle speed to your Gcode (S0 = minimum PWM ; S100 = maximum PWM).
You need to be using Mach3 version R3.043.056 or later.
« Last Edit: June 14, 2016, 10:20:19 AM by Tweakie.CNC »
  •  9,375 9,375
Re: Laser M10P1
« Reply #11 on: June 15, 2016, 01:10:20 AM »
If you wish to test the circuit / setup without it being connected to the laser PSU then temporarily connect the components shown in red.
With this and when Mach3 is set-up as described then the commands…
M3
M11P1
S100     should indicate 5 Volts
S50       2.5 Volts
S0         0 Volts
Etc.
« Last Edit: June 15, 2016, 10:14:50 AM by Tweakie.CNC »
Offline Snues
  •  16 16
Re: Laser M10P1
« Reply #12 on: June 15, 2016, 07:45:09 AM »
Hey Tweakie
I assembled everthing like you told me. I have version R3.043.066 and adjusted all the things as you texted me.
To get everthing right, should i connect a 5 volt source (4,5 also possible?) as +pole with the 10k , the -pole with Gnd and place the gauge in between?
Bernd
  •  9,375 9,375
Re: Laser M10P1
« Reply #13 on: June 15, 2016, 10:13:59 AM »
4.5 Volt would be OK, connect as shown in the diagram (+pole to the 10k and -pole to GND).
Offline Snues
  •  16 16
Re: Laser M10P1
« Reply #14 on: June 15, 2016, 01:06:19 PM »
Hey Tweakie
Last time to be totally sure...is it at the 1st picture a 10k resistance and at the 2nd one a 10k potentiometer?
1.)
2.)
  •  9,375 9,375
Re: Laser M10P1
« Reply #15 on: June 16, 2016, 12:28:39 AM »
You are correct sir.
Offline Snues
  •  16 16
Re: Laser M10P1
« Reply #16 on: June 16, 2016, 05:02:26 AM »
Hey Tweakie
I have set up the curcuit layout without the power adapter and 4,5V battery and it works. But it shows me at  OV at S100, 2,25V at S50 and 4,5V at SO, shouldn't it be the other way?
Bernd
  •  9,375 9,375
Re: Laser M10P1
« Reply #17 on: June 16, 2016, 06:49:18 AM »
That sounds correct.
When using the TTL(L) input to the laser PSU 0Volts is maximum laser power output and 5Volts is minimum laser power output.
However, to reverse the voltage slope just change the Step Low Active state of the Spindle (Config. / Ports & Pins / Motor Outputs).
Offline Snues
  •  16 16
Re: Laser M10P1
« Reply #18 on: June 18, 2016, 10:30:28 AM »
Hey
Thanks for your help, now really the very last question, is it mandatory that the potentiometer has 10k? cause i don't have a 10k one
Bernd
  •  9,375 9,375
Re: Laser M10P1
« Reply #19 on: June 18, 2016, 10:46:56 AM »
It is not mandatory. I would think any value between 1K and 22K would be OK.
(I use a 10K, 10 turn, potentiometer with calibrated dial).
