Hello Guest it is November 08, 2026, 08:12:02 PM
Author Topic: backing off home switch  (Read 12918 times)
« on: April 26, 2016, 12:48:49 PM »
 Hello when my machine is set to ref all home the z-axis goes to trip the switch but it will not back off. The reset button lights and I have to turn the power off move it off the switch by hand then power it back up and hit the reset button. Then the machine will move again
    Thanks Bruce
Re: backing off home switch
« Reply #1 on: April 26, 2016, 12:54:30 PM »
same for me think its the wiring of the switches  I been told :)
« Reply #2 on: April 26, 2016, 02:49:36 PM »
  I figured it out    thanks       that's what is was my switches were wrong.
« Reply #3 on: April 26, 2016, 03:03:55 PM »
if you have a wiring diagram would be helpful
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: April 26, 2016, 03:27:47 PM »
This can be caused by switch bounce - try adding some debounce in settings, maybe 2000 and work downwards.
« Reply #5 on: April 26, 2016, 06:47:08 PM »
  Thanks for the answers I had the switches wired wrong. I fixed it.
 Thanks all
 Bruce
