Hello Guest it is November 02, 2026, 10:06:54 PM
Author Topic: Router will smooth out corner moving from +X to -Y  (Read 7539 times)
« on: April 25, 2016, 08:13:19 AM »
Hey guys,
I have a problem with the machine making a radius when it should be a hard 90 deg. turn.  It seems to only be when the machine goes from +X to -Y.
I have played around with the velocity settings and it seems that the error gets greater as the velocity increases.
I have used the same program block by block and it works fine.
Any suggestions??
Re: Router will smooth out corner moving from +X to -Y
« Reply #1 on: April 25, 2016, 10:29:04 AM »
In General Config, check "Stop CV on angles >" and set it to 89°.
Your in CV move, and Mach3 is trying to maintain a constant velocity as it goes around the corner.
