Hello Guest it is November 08, 2026, 08:30:41 PM
Author Topic: Problem with MACH3  (Read 11120 times)
Problem with MACH3
« on: April 25, 2016, 06:15:49 AM »
HI when I got my cnc 3040 router it came with a cut down version of mach3 I connected switch it on installed the software it all worked then did not use it down to cold weather and health problems and hard drive failed I have not used it then re built the computer and installed new version around end of feb this year I sort of played with it but it stops at about 50 LInes and not sure what the problem ...thought I ask I got from one of your partners   (Cnc4you Ltd)
Re: Problem with MACH3
« Reply #1 on: April 25, 2016, 09:54:10 PM »
Have you installed your  license?
 Unlicensed / demo mode of Mach3 is limited in the number off code lines.
« Reply #2 on: April 26, 2016, 01:48:50 AM »
yes its a .dat file
« Reply #3 on: April 26, 2016, 05:18:08 AM »
I must say that personally I don't provide any support for any of the Chinese stuff like a 3040, etc.
Don't know what a cut down version of  Mach3 is.
Post a link to exactly what and where you got the license from.
Post the xml file that you are using.
« Reply #4 on: April 26, 2016, 05:48:27 AM »
sorry I was try and tell you the router came with a cut down version I did say I used it to see if it work for only 5 mins and because it was a old computer install a new H/drive and then i got a License for mach3 from a partner of yours ( I do buy lost of software) I don't use pirate software
Cnc4you Ltd www.cnc4you.co.uk 37 Alston Drive
Bradwell Abbey
Milton Keynes
MK13 9HA Buckinghamshire United Kingdom (UK)
P.S I am talking about mach3 not a 3040 trying to find out y this software not working after paying for it wish I had not :(
By the way I am not using the version that came with 3040 using the one from download area XML File I have to give it to you in a few days moving the cnc a round at the moment and with health more like be the weekend .
« Last Edit: April 26, 2016, 05:51:42 AM by 01012k7 »
« Reply #5 on: April 26, 2016, 03:51:48 PM »
Can you attach your xml please, may find the problem in your config if I can view it.
