Hello Guest it is November 13, 2026, 03:22:57 AM
Author Topic: Mach3 need one more input for Pressure sensor?  (Read 35217 times)
Re: Mach3 need one more input for Pressure sensor?
« Reply #20 on: April 16, 2016, 04:59:58 PM »
Ok which brain is it you are using, there are 3 that are enabled
OP78LED
ModIOMPG
PSI11
I presume it is the last one?
« Reply #21 on: April 16, 2016, 05:11:26 PM »
The brain has an issue, not sure exactly what but I deleted all the steps in it and redid and saved, then reloaded and it works fine.
« Reply #22 on: April 16, 2016, 05:15:37 PM »
Hood yes the last one is the brain that I am using.  I will try to delete the brain and then start over if thats what you did and it works.
Thanks for sharing your knowledge!
Jeff
« Reply #23 on: April 16, 2016, 05:16:09 PM »
Can you show me what the brain looks like that you did?
« Reply #24 on: April 16, 2016, 05:16:28 PM »
Maybe I did something to the brain when i was making it.
« Reply #25 on: April 16, 2016, 05:20:24 PM »
Here is the brain.
I just deleted the steps in it and started again rather than totally deleting the brain, same difference I suppose.
« Reply #26 on: April 16, 2016, 06:00:08 PM »
Hood Thank You so much for your time I will give it a shot!
Jeff
« Reply #27 on: April 16, 2016, 06:16:38 PM »
Hood you are not going to believe this but I had it right all along from when you first showed me.  In the Inputs ports and pins I had the wrong pin!!!!  I had 3-7 and works when I have the right port and pin 3-8!!!  Well I feel stupid!
Thanks for the help
