Hello Guest it is November 18, 2026, 05:28:36 PM
Author Topic: error, but only when calling from within Mach3  (Read 8882 times)
« on: May 18, 2007, 10:39:28 AM »
My problem is such.. Used the VB editor within Mach to edit... which is frustrating enough, as it is not saving reliably.... ugh..
using the "play" button in the editor, checks out fine.. works fine..  everything SEEMED to work fine yesterday when i wrote all this, but now i'm getting an error "error on line 84--internal error <homeit>"
This corresponds to the "getoemled(800)" line within the "homeit" sub...
also getting an error on Line 88... corresponds to "msgbox........" line
this code is contained within the "reset" button, and I'm using it to do maintenance prompts, and a "must home before running" lockout...
anybody have any thoughts/suggestions?
Thanks in advance!!
*edit* running mach Version R2.0.061  on the laptop being used for testing anyway.
'Purpose:
'Every Monday, when the Machine is brought out of a "reset" state, a prompt is initiated to grease
'the machine.  A Maintenance Log is created/appended with a time/date stamp, and an Operators Name.
'If the Date Stamp is the same as the last stamp in the maintenance file, the maintenance request is ignored.
'The state of the machine is checked upon coming out of The reset, and in conjunction with the "ref home" and "cycle start"
'buttons, a "HOME" action is forced prior to running ANY GCode Files.
Sub Main()
   Call Maintreminder()   'determine if maintenance is required & take care of process if necessary
   Call Homeit()      'Warn about homing after reset & prevent Gcode runs
End Sub
'* Subroutine: Maintreminder
'* Purpose: create a maintenance reminder prompt every Monday upon Resetting the machine
'* Programmer: Nathan Haskell
'* Date: 5-17-07
Sub Maintreminder()
Today = Date ()                  'Obtain Current Date
   DOW = Weekday (Today)               'Calculate Day Of Week (1-7)
   Clk = Time()                'Obtain Time Of Day
   Open "Maintenance.txt" For Input As #1         'Search Maintenance Log for last
   Do While Not EOF (1)               'Maintenance Occurance
   Line Input #1, Lastline
   Loop
   Close #1
   LastMaint = DateValue(Lastline)
   If DOW = 2 Then               'Check to see if Today is Monday
      If Today = LastMaint Then         'And compare against the last Maintenance Log
      Exit Sub               'If the last Maintenance Log was from Today, ignore
      Else
                        'Otherwise, Perform Maintenance Routine!
      Begin Dialog Maintdlg1 60,60, 200,70, "Maintenance Required!"
      TEXT 60,10,90, 12, "Machine Must Be Greased"
      TEXT 10,24, 50,12, "Operator Name"
      TEXTBOX 60, 22, 108, 12,.nameStr
      OKBUTTON 80, 54, 40, 12,.okbtn
      End Dialog
           '* display the dialogbox for operator name input until a valid name (aka, anything starting with A or greater) is displayed...
           '* Also continue to display until the "OK" button is pressed, to eliminate just clicking out of it...
      Dim Maintbox As Maintdlg1
      Do
         Do
         Dialog Maintbox
         Loop Until Maintbox.nameStr >="A"
      Loop Until Maintbox.okbtn=-1
      MsgBox "Thank you " & Maintbox.nameStr & "!"
      Open "Maintenance.txt" For Append As #1
      Print #1, " "
      Print #1, "Greased at "  & Clk & " By " & Maintbox.nameStr
      Print #1, Today
      Close #1
      End If
   End If
End Sub
Sub Homeit()
   If GetOEMLED (800) = false Then               'If Placing into a Reset, then just reset
   DoOEMButton (1021)
   Exit Sub
   Else                        'Otherwise, Call the message box, then reset
   MsgBox "Machine Must Be Homed After Startup Or A Reset"
   DoOEMButton (1021)
   End If
End Sub
« Last Edit: May 18, 2007, 10:44:48 AM by howling60 »
Re: error, but only when calling from within Mach3
« Reply #1 on: June 21, 2013, 11:03:16 AM »
Thanks in advance!!
'Purpose:
Sub Main()
End Sub
'* Date: 5-17-07
Sub Maintreminder()
   Loop
   Close #1
      Else
      End Dialog
      Do
         Do
         Dialog Maintbox
      Print #1, " "
      Print #1, Today
      Close #1
      End If
   End If
End Sub
Sub Homeit()
   DoOEMButton (1021)
   Exit Sub
   DoOEMButton (1021)
   End If
End Sub
Hello,
did you get it work and if possible then please explain to me where to put those macros.
Rait
