Hello Guest it is November 13, 2026, 05:54:16 PM
Author Topic: Mach4 using 57E and kbd48CNC  (Read 11160 times)
« on: April 11, 2016, 03:52:06 PM »
I'm trying to bring my Bridgeport to life. Motion control is taken care by Vital Systems DSPMC/IP, I'm using a Poykeys 57E with kbd48CNC, and a pendant.
Is there any plug-in for the kbd48CNC, or even documentation. I've used the Pokeys wizard to set up the 57E and checked kbd48, but can't seam to make and thing happen with the keys. Do I have to map each key?
Re: Mach4 using 57E and kbd48CNC
« Reply #1 on: April 13, 2016, 03:25:31 PM »
hi,
i have used this combination for an maho600!
But under mach3.
you will find the documants for the kbd48cnc on the polabs homepage.
For an mpg under Mach3 you have to make the tick under "let pokey handle MPG jogging".
For this combination it is only important, that you don“t use the Pulse Engine.
Good luck
 ;D
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #2 on: April 13, 2016, 11:12:52 PM »
Tig-140 contacted us by emails ([mach1mach2cnc] yahoo group) - https://groups.yahoo.com/neo/groups/mach1mach2cnc/conversations/messages/150613
