Hello Guest it is November 07, 2026, 10:49:27 AM
Author Topic: is this stepper big enough?  (Read 14553 times)
« on: April 10, 2016, 07:17:12 AM »
Hello Chaps --
I am not in the least accomplished in electronics and electrical stuff
Firstly -I have heard that steppers have there most torque when running very slowly?
Is this correct.
Therfore am i right to assume that a direct connected drive will be the most powerful way of
connecting the stepper to the leadscrew??
I am attaching a picture of a stepper motor ( no names or labels on it ) and a picture of
my benck milldrill. Can anyone tell me if the stepper shown will be OK for connecting to the
mill drill shown by a direct drive onto a 5mm pitch ball screw?
the drive will be powering the left to right feed and the front to back feed
Would it be better to use a toothed belt and gear the motor speed down ? small pulley on
motor bigger pulley on lead screw??
All comments will be appreciated
And many thanks
Fred Evans
Offline Davek0974
  •  2,606 2,606
Re: is this stepper big enough?
« Reply #1 on: April 10, 2016, 08:47:04 AM »
Can't see the motor ;)
Can you also post the dimensions of said motor?
« Reply #2 on: April 10, 2016, 10:27:30 AM »
sorr something went wrong?
the motor is  55mm X 55mm X 75 long ( excluding shaft which protrudes about 20 mm
I attached the motor picture to this mail
rergards
fred
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: April 10, 2016, 10:46:47 AM »
Looks like a Nema23 3Nm motor with those dimensions.
A direct drive to 5mm ball-screw would likely work.
« Reply #4 on: April 10, 2016, 06:13:33 PM »
Is this correct.
The torque is max at the slowest rpm of the stepper and degreases as the rpm increases. So yes, BUT,
you also want to have a decent axis resolution by micro stepping, adding gearing increases delivered torque.
Without any motor model / make you know nothing of that motor. You could mount it such that you turn the shaft and see max generated voltage.
Also can measure resistance, capacitance/ inductance of the windings. All a trade off of speed, torque, axis resolution.
Suggest you go to the Gecko Site as they have a lot of info on steppers to increase your understanding
BTW, Steppers are rather cheap these days and worth buying new and thus you know what to expect when installed.
« Last Edit: April 10, 2016, 06:15:14 PM by RICH »
« Reply #5 on: April 12, 2016, 05:37:18 AM »
Thanks chaps-- Hmm yes i didnt think of the microstepping bit
I will look at the gecko page and try and glean as much as possible
How many steps per rev would be typical for a stepper like this??
 Then i can work out the resolution that i am likely to get
Just an aside-- Yes the steppers are very inexpensive now- but you know
the South African Rand has devalued so dramatically that everything has
become unaffordablly expensive. I remember when our currency was
R1.40 to a pound sterling. It is now usually over R20.00 to a pound.
Thanks for the advice anyway
fred
Offline Davek0974
  •  2,606 2,606
« Reply #6 on: April 12, 2016, 05:56:46 AM »
Usually 200 steps per rev, but there are other flavours but my guess is 200.
« Reply #7 on: April 12, 2016, 06:06:05 AM »
fred,
You will find info in Members Doc's on how to calculate steps per unit. There is a spread sheet
which makes it easy. If you have a torque wrench you could test to see how much holding torque is available.
« Reply #8 on: April 12, 2016, 06:31:50 AM »
thanks all-
regards
from
south africa
