Hello Guest it is November 04, 2026, 12:03:38 AM
Author Topic: Motor tunning with CSMIO/IP-A (PID) Trouble with encoders  (Read 163327 times)
Re: Motor tunning with CSMIO/IP-A (PID) Trouble with encoders
« Reply #40 on: October 03, 2016, 02:19:27 AM »
i changed the amps and the servos from callan type DC motors to modern servos, because i can´t find  amps with +- 10v input, 120v DC and 90A peak for the callan type motor..
used servos about 200€ and amps about 250€ on ebay.
« Last Edit: October 03, 2016, 02:21:05 AM by gravie »
« Reply #41 on: October 06, 2016, 11:32:43 PM »
Will search on ebay. What is your problem ? Is  the motor constantly correcting the position?
« Reply #42 on: October 07, 2016, 11:46:32 AM »
no, that isn´t a problem.  this is  normal with linear scales on modern milling machines.
the problem is the precise and quick  positioning with linear scales and spindle clearance.
i think, it would works better with encoders and spindle clearance.
« Last Edit: October 07, 2016, 11:49:42 AM by gravie »
« Reply #43 on: October 07, 2016, 12:03:38 PM »
But than you lose the precision ? Or I'm mistaken ? . h. Now i would like to know can you remove the back slash just between the servo driver and servo motor ? And than use the linear scales for feadback to the csmio?
« Reply #44 on: October 08, 2016, 07:22:05 AM »
But than you lose the precision ? yes
i use the linear scales with csmio.
the servo amp use the servo encoder signal (internal), but i can connect the csmio input to the servo amp encoder simulation output.
i receive next week 2 ball screw spindles for x and y axis and than i remove the gears and change to belts.
« Last Edit: October 08, 2016, 07:30:13 AM by gravie »
« Reply #45 on: October 08, 2016, 09:58:43 AM »
Thanks for the answer.
Can you tell me which belts and pulley are you going to use?
« Reply #46 on: October 08, 2016, 11:14:04 AM »
hdt belts, 8 pitch, 25mm wide
22  tooth pulley on the servo side and 44 or 32 (y axis, no more space) tooth on the spindle side.
« Last Edit: October 08, 2016, 11:15:39 AM by gravie »
« Reply #47 on: October 15, 2016, 09:35:13 AM »
the x and y axis  conversion kit is ready to mount.
i hope, it works...
« Reply #48 on: October 23, 2016, 07:54:27 AM »
i switched the x and y axis now to belt-drive.
the pid tuning is much better than with  gears, but my spindle is not the best qualitiy.
i think, with zero gap spindles it works perfekt.
https://www.machsupport.com/forum/index.php/topic,33125.msg232442.html#msg232442
« Reply #49 on: February 08, 2017, 10:39:19 AM »
Greetings,
i have been also working on my machine these past couple of months.  To sum up what i have done so far.
I have changed  the energy chain and the linear scales. Also i have painted the whole machine. Now i have changed the operators panel
and added an cabinet for the new drivers for servomotors. For now i will stick with the gear transmission between the motor and spindle.
Will add a movie of my progress as son as i find some time.
Also the tuning is going to be a pain in the A**.
Here is also my thanks for HOOD he has helped a lot ! Thank you !
Best regards
Slovenec
