Hello Guest it is November 02, 2026, 10:05:42 PM
Author Topic: Run From Here & macros  (Read 10427 times)
« on: April 08, 2016, 08:38:35 AM »
Does anybody have experience with RFH behavior when code contains macros? I have situation that while it rewinds the code to get the RFH line, it executes all macros before. For example, there are macros that contain activate / deactivate outputs (pneumatic valve solenoids) and when I scroll to the desired line and press RFH button, it starts running thru the code, activating/deactivating solenoid quickly unill it stops at the desired line. Using licensed 066 with ESS. Ignore M cals while loading is checked.
Thanks in advance,
Re: Run From Here & macros
« Reply #1 on: April 30, 2016, 09:24:07 AM »
Anybody please?
BR
« Reply #2 on: April 30, 2016, 04:09:29 PM »
That will happen when doing RFH I am afraid.
Offline rcaffin
  •  1,073 1,073
« Reply #3 on: May 10, 2016, 05:30:58 AM »
Some of us avoid ever touching that button. There be dragons.
Roger
