Hello Guest it is November 13, 2026, 05:11:52 PM
Author Topic: MPG problem  (Read 12467 times)
MPG problem
« on: April 06, 2016, 01:06:34 AM »
Hi I'm working on a CNC mill with Pokeys 56U and  I want to make it work with an old MPG that has 4 terminals A,B,Ground and Positive. Now, I used the MPG manual and connected the terminals to Pokeys board in A=>Pin1, B=>Pin2 and made alll the configurations.
Now I can move the axis when I select the jog mode, but the problem starts when I change axis. When I chose the X axis and turn the handweel it moves correctly, but when I turn to Y axis (Alt A) it starts moving like 7in alone (without moving the handweel) and if I don't move the handweel and press Alt A again the Z axis moves too.
Do you have any ideas?
Thank you for your time.
Offline NeoTO
  •  504 504
    • PoLabs
Re: MPG problem
« Reply #1 on: April 06, 2016, 02:11:08 PM »
1. Do you have the latest Mach3 and PoKeys plugin?
2. Do you have 'Let Pokeys handle MPG jogging' option enabled in the plugin settings?
Re: MPG problem
« Reply #2 on: April 06, 2016, 02:36:24 PM »
In mach3 I have  3.043 and in Pokeys i have 3.1.55
And yes it's enable Let Pokeys handle MPG jogging
In 'Encoder Settings' I have Encoder1 Enable Checked, Pin1, Pin2, Invert Unchecked, 4X unchecked, DRO 101:...,and Pedant Checked
Thank you.
Offline NeoTO
  •  504 504
    • PoLabs
Re: MPG problem
« Reply #3 on: April 06, 2016, 10:47:57 PM »
I would strongly suggest to update both the Mach3 and the PoKeys software with the plugin before continuing.
Re: MPG problem
« Reply #4 on: April 22, 2016, 10:56:10 AM »
Hi NeoTo sorry I have some problems.
I am searching the mach3 and pokeys update but I only found a installer where  I need to have internet in the PC. Now, in the machine I'm working I dont have internet and is difficult connect it.
Do you know if I can download a file with the installer? and can I use the same license?
In the web page of POLABS I can't find the update to pokeys. Can you help me with this too?
thanks for your help.
