Hello Guest it is November 13, 2026, 10:33:32 PM
Author Topic: WIZARD WRITE  (Read 8153 times)
WIZARD WRITE
« on: April 05, 2016, 09:19:29 AM »
I have a license but can not get WRITE to post the g-code to Mach3. It still says no lic. all the other wizards work ok
Re: WIZARD WRITE
« Reply #1 on: April 05, 2016, 09:47:35 AM »
can anyone make any suggestions as to how to get it to function?
Re: WIZARD WRITE
« Reply #2 on: April 05, 2016, 11:36:31 AM »
You don't need a license to use the write wizard?
Look very carefully and make sure you select all the options. If you leave some options unselected it doesn't work.
