Hello Guest it is November 13, 2026, 09:46:43 AM
Author Topic: Gcode mishaps  (Read 32701 times)
Gcode mishaps
« on: April 02, 2016, 04:45:38 AM »
Hi everyone. I am having trouble with either getting false e stops or running out of data on my ether net smooth step. The gcode that I am running is short it is face milling my cnc bed. I had bobcad support look at the file to see if everything is good and it is. Soon times when I first go to run the code the z axis goes from zero away up in the + and it is supposed to go up 2 then go to -.001 and start cutting . I cannot for the life of figure out what is going on need help
  •  9,377 9,377
Re: Gcode mishaps
« Reply #1 on: April 02, 2016, 05:24:03 AM »
Zip and post (attach) your Gcode file.
Re: Gcode mishaps
« Reply #2 on: April 02, 2016, 07:53:03 AM »
If you jog the z in the positive (Z+) direction, which way does the machine move, up or down?
Re: Gcode mishaps
« Reply #3 on: April 02, 2016, 03:04:37 PM »
I was making the top for the bed drilling holes in it and without running a gcode it still was spontaneously throughing a estop. The more I did the more often it began kicking off even without moving and with or without the spindle on. What do you think is the cause
Re: Gcode mishaps
« Reply #4 on: April 02, 2016, 03:06:54 PM »
When I jog in the +it moves up as it should all other axis are good too.
Re: Gcode mishaps
« Reply #5 on: April 02, 2016, 03:24:04 PM »
Is there a physical/mechanical e-stop button wired to your machine ?
If so, is it also wired to your computer so Mach "see's" it ?
~ What was once an Opinion, became a Fact, to be later proven Wrong ~
Re: Gcode mishaps
« Reply #6 on: April 02, 2016, 03:29:54 PM »
There is a mechanical estop button wired to the brakeout board wire to 5 volts and pin 10
Re: Gcode mishaps
« Reply #7 on: April 02, 2016, 03:34:57 PM »
I had to disable the limit switches 1 wire on a switch broke and haven't had a chance to fix it yet .
Re: Gcode mishaps
« Reply #8 on: April 03, 2016, 07:54:25 AM »
I mite have found 1 problem it was with my ether net smooth stepper. I had to go into it and set the filter for rf noise from zero to 1.43. I mite have to increase it by .10 but you can't go over 10.00. I found this out on the net posted by Hood.
Re: Gcode mishaps
« Reply #9 on: April 04, 2016, 04:03:00 PM »
Here is my nc file for you to have a look at. The file works good but I have to run it from line 6 or six.
