Hello Guest it is November 13, 2026, 08:00:54 PM
Author Topic: Need Info  (Read 8610 times)
Need Info
« on: March 27, 2016, 11:09:09 AM »
Question:
I am making screws in 1/8” mild steel.
I will drill a small hole in the metal. Then heat it to red & punch a hole the size needed to put a screw in it.
(1)   I understand that after the metal cools down the hole will become slightly larger & the punch will come out easier. Is this correct?
(2)   In the code can I put in a delay of 15 seconds before the CNC machine goes to the next hole, so I have time to heat up the next hole?   What is the code?
(3)   I need a router that runs very slow & powerful to make the screw threads. Is there a router out there & where I can buy one?
(4)   I then need to make the screw threads with a cutter that doesn’t cut the screw threads just forms it.  Where can I get one?
Thanks for the help
Rkjohn
Re: Need Info
« Reply #1 on: March 27, 2016, 12:58:52 PM »
I'd look at flowdrill.com first as it may save you a bunch of work. I have seen this demonstrated at various shows using a drill press so it should work great on a CNC.
Offline Davek0974
  •  2,606 2,606
Re: Need Info
« Reply #2 on: March 27, 2016, 03:25:42 PM »
Just an FYI, thread forming cutters are generally only used in soft metals like aluminium, generally you would cut a thread in steels.
I think the code for a delay would be G04 P15.00
