Hello Guest it is October 24, 2026, 03:38:13 PM
Author Topic: Plugins not showing in profile  (Read 7871 times)
« on: March 26, 2016, 03:29:54 AM »
Hallo
I purchased both the parallel license and the Mach 4 licensing, all licensing installed and no messages showing licensing issues.
I created a new milling profile, In the Driver I can select the parrallel port which is all setup as per the video, but when selecting plugin the list is empty.
Any advise?
Jacques.
Re: Plugins not showing in profile
« Reply #1 on: March 27, 2016, 02:21:12 AM »
You have to copy the files from the "parallel port" Plugin in to the plugin folder.
If you made default installation the folder is located here: "C:\Mach4Hobby\Plugins"
Best regards,
Gerhard
« Reply #2 on: March 27, 2016, 04:03:38 AM »
Hallo Gerhard
Thanks, yes thanks, I copied the three files to the profile and all up and running now.
Thanks for the assistance.
Best Regards,
Jacques
