Hello Guest it is September 17, 2026, 09:37:49 AM
Author Topic: GREX and Direct Connect Via Second Net Card.. HELP!  (Read 36187 times)
Offline mhdale
  •  130 130
  • Knowledge is the Treasure.
    • Black Dragon Technologies
« on: May 17, 2007, 10:03:56 AM »
Hello all, I am having trouble creating a direct connection to my GREX..... It has been working fine through a HUB but now I would like to streamline the connection and connect it directly to my control system via a crossover Cable.... I have installed the Network Card and connected it to the G-REX via a crossover Cable .... It says I am connected but it is unable to find the GREX when I start MACH 3... what are the setting necessary to have this work? Use Small word please its been an early morning and My brain seems to having trouble starting this AM... Thanks in Advance
Mike
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: GREX and Direct Connect Via Second Net Card.. HELP!
« Reply #1 on: May 19, 2007, 02:44:22 AM »
Without some more detailed info i am just going to make a stab at it.
You probably have to give your second nic a ip address. And you have to make sure that the grex has a similar address.
Comp (second nic)  10.0.0.1 Sub net 255.255.255.0
Grex 10.0.0.2 sub net 255.255.255.0
192.168.0.********* will work also just make sure it is different from the main nic.  You will probably have to use you hub to connect and change the ip to whatever you plan on using on your second nic..
Chad
« Reply #2 on: May 20, 2007, 09:45:55 PM »
Chad
To add what Chad said, Don't put a 'default gateway' on the second nic; just leave that field blank.
Bryan
Offline mhdale
  •  130 130
« Reply #3 on: May 21, 2007, 05:29:41 PM »
Thanks Guys, This is the first time I have tried to setup multiple NIC's in a Single puter before, The connection works when I use the Main Ethernet connection but the second NIc wont connect..... Do I need to have the connections Bridged? do bothe NIcs need a distinct IP address?
M
« Reply #4 on: May 21, 2007, 07:53:28 PM »
Do not bridge the connections and yes you can leave your first nic settings alone. Create a new network address for the second nic (ie 10.1.1.1 and subnet mask 255.255.255.0)
Offline mhdale
  •  130 130
« Reply #5 on: May 21, 2007, 10:09:30 PM »
Thanks I will Give that a try. It would be nice to get this machine on the local network, it will simplify updates and maintenance.
Mike
« Reply #6 on: May 24, 2007, 12:37:10 PM »
Hey Mike, did you get this sorted? I'm going to be trying the same thing soon.
Offline mhdale
  •  130 130
« Reply #7 on: May 24, 2007, 04:01:40 PM »
Brett, Do you mean have I actually got Both NIC Cards talking and the GREX hooked up... no, currently the machine I am working on is standalone and so I have not been spending too much time sorting it out as it is not priority. I have the grex talking directly to the PC via the On board MB NIC connection, when I get around to it I will be hooking up the second NIC Card to the lLAN and see if that works .... I will keep you posted.
Mike
« Reply #8 on: May 24, 2007, 04:22:10 PM »
Yup, that is what I was meaning. Thanks Mike.
« Reply #9 on: May 25, 2007, 05:04:52 PM »
No luck from me on installing a second network card either. I have attached a screen shot. I know very little about networking but would really like to get this sorted.
Edit
I also meant to say I tried it without the default gateway entered to.
« Last Edit: May 25, 2007, 05:09:05 PM by Chaoticone »
